Camt update total fuel value.
Postby Nikolaos » Sun May 12, 2013 10:02 pm
I am unable to update the total fuel value from the HXr screen. I have no problem doing it from the EIS, however, when I get to the proper screen on the HXr and I turn the right dial the number doesnt change. It appears like its starting to change but goes back to the original value
Any ideas as to what might be causing this?
Nikolaos
Re: Camt update total fuel value.
Postby GRTBen » Mon May 13, 2013 12:44 pm
Nikolaos
If there is a value other that 0 in the EIS the number on the HXr wont change. If you are entering it on both EIS and EFIS the EIS gets priority and will override the HXr setting. Set the fuel number on 0.0 and you will be able to adjust the value on the HXr.
GRTBen
Tech Support
GRT Avionics
GRTBen
Postby Nikolaos » Mon May 13, 2013 4:28 pm
Thanks Ben
I will try that out.
Nikolaos
Users browsing this forum: No registered users and 9 guests
