Multiple powers In
Postby MolsonB » Mon May 16, 2016 1:14 am
How does the 3 multiple power inputs perform? I assumed A is main, B is secondary if A is missing. And C is the last one if A and B are missing. Out of curiosity, I hooked up Amp meters in-between and noticed if all three powers are applied, they share the amps in-between each other. I thought they would be isolated from each other inside the HXr.
My thoughts are, A is powered from Main Bus. B is powered from Aux Bus, and C is powered from standalone backup battery. Leaving them all connected directly without switches in-between would allow fail-over without human intervention.
MolsonB
Re: Multiple powers In
Postby Bobturner » Mon May 16, 2016 4:24 am
I believe they are identical. Most of the current will be drawn from the input with the highest voltage. Current will not flow backwards, out one of the inputs.
Return to Horizon HXr
