Fuel totalizer fuel remaining - decimal/integer
glenn
Post by glenn »
The fuel totalizer fuel remaining displayed on the HXr is an integer but the entered value seems to be decimal. So when I added 35.0 gallons of fuel it is displaying 350 gallons. I can't seem to find the setting to change that on the HXr or the EIS. Does anyone know where that is configured?
Regards,
Glenn
Velocity Elite RG
Widget
Re: Fuel totalizer fuel remaining - decimal/integer
Post by Widget »
Look at section 7.1.6 n the EIS installation manual and it shows how to select these.
In the EFIS you can also select digital or Interger. I thinks it's in the General men, but scroll through until you find the AUX settings and you can then select digits or intergers.
Jerry "Widget" Morris
glenn
Post by glenn »
Jerry,
Thanks, but that wasn't the problem. However, I did just find what was. The HXr is displaying the Fuel Remaining in a dial. The dial scale was set to 1. I changed it to 0.1 and now it works correctly.
Regards,
Glenn
Regards,
Glenn
Velocity Elite RG
