G-Meter display
kwiatkma
G-Meter display
Post by kwiatkma »
Hello all! What would be the trick to,have the Gmeter always display? Should I set the limits really low or ????
I think I've worked all the bugs out and I'm finally getting to enjoy the panel!
Also what is the location on the screen to look for the Gmeter information?
Re: G-Meter display
The g meter won't show if you have selected to show flap position. They both display in the same area.
kwiatkma
Re: G-Meter display
Post by kwiatkma »
Bobturner,
Can you tell me what page that setting is on for the flap display AND how to disable the flap display? I don't have flaps, and I can't seem to find the setting options....on any of the setup pages??? Still on a learning curve of the setup options.
I've also got to re calibrate the fuel flow meter....it's way off!
Re: G-Meter display
You turn on the flap display at the analog input setup.
kwiatkma
Re: G-Meter display
Post by kwiatkma »
Bob turner ,
Thanks a ton. I got it! Pulled 2g's in a tight turn today!
