Trig transponder default squawk code
Postby TONYBISHOP » Mon Aug 28, 2017 1:34 pm
We've installed the Trig without the Trig head. We can set up just about everything through your interface, except the default squawk. In Europe the default squawk code is 7000; I think it varies around the World. Could you provide a command for this please? (With the Trig head installed, there's an option for this).
Also the link to this forum has disappeared with the (rather nice) website redesign....
TONYBISHOP
Re: Trig transponder default squawk code
Postby GRT_Jeff » Tue Aug 29, 2017 6:31 am
The default squawk code is set in General Setup because other transponders also use it. SET MENU, General Setup, VFR Squawk Preset. It's near the bottom of General Setup.
Return to Horizon HXr
Users browsing this forum: No registered users and 6 guests
