Audio & discrete outputs
Postby MolsonB » Wed Oct 18, 2017 1:53 am
On the HXr, Audio Out Hi is pin B24. Is there an Audio Out Lo?
Hooking up to PS-Eng PAC15EX
And I'm guessing the 8 discrete outputs are A6 - A13?
MolsonB
Re: Audio & discrete outputs
Postby Bobturner » Wed Oct 18, 2017 4:44 am
On some units B25 is audio low. Otherwise use any ground.
Postby GRT_Jeff » Thu Oct 19, 2017 12:07 am
On every HX and HXr, B25 is audio ground.
The 6 discrete outputs are B8 through B13. See the attached older connector document (it is still accurate for all HX and HXr).
HX Display Unit Connector Definitions Rev A.pdf
(73.14 KiB) Downloaded 136 times
Postby MolsonB » Thu Oct 19, 2017 1:27 pm
Ah look at that. Perfect. Haven't seen that doc before. Weird how it never got transferred over to the new documents.
Thanks Jeff for the info.
MolsonB
Users browsing this forum: No registered users and 8 guests
