Tank Levels Again!
Posted: Thu Dec 31, 2015 10:07 pm
I want to re-calibrate the tank floats. But would like to make sure of a few items first.
The table you fill out in the EFIS with the readings, do I need to clear it before starting again?
What is the "raw value" showing at the bottom of the "probe-actual" table?
When starting and tank is empty, and say gauge is showing 2, I start adding fuel and the 2 starts flickering to 3 and
I have added 3 gallons. Do I call this the float starting to move point? What do I put in the table, probe 2 actual 3?
You are supposed to be watching the number above the tank level green bars...right?
Right now, after a few flights, the right tank has 7 gallons and is reading 11 on EFIS, would like it closer.
I have read the float instructions from GRT numerous times and still not sure.
Plane is RV9A.
I have the HXr on the left and HX on the right. Do I need to fill out the table on the HX too or does the
HXr communicate to it? I have them tied together with the ethernet cable.
Many Thanks for any help
Bert
email: bert1950@cox.net
Plane is RV9A.
Bert
