Fuel Qty reading Dial indicator Wrong.
Posted: Thu Mar 21, 2013 12:39 pm
by Kahuna
I have finally gotten my capacitive sensors working and now have odd dial readings. The numbers are correct, but you can see from the picture that the dial needles do not represent the number.
Dial #3 set between 1 and 20. changing these numbers does not change anything on the dial at all. Left tank # is 0 which is accurate but needle not at zero. Right tank 9 also accurate but needle at full.
Any idea what this might be? :?
Re: Fuel Qty reading Dial indicator Wrong.
Posted: Thu Mar 21, 2013 3:27 pm
by Widget
From where the 0 needle is pointing I would think the digital/integer decimal places may be wrong. I think you can set these to points/ones/tens somewhere in there.
Posted: Thu Mar 21, 2013 5:25 pm
by Kahuna
Well Ill poke around here some more. There are only a few settings for the dial. Ive played with them all. They dont seem to do anything. I played with the dec int values, no change.
Posted: Fri Apr 12, 2013 9:31 pm
For the "Fuel (Combined)" dial, the fuel maximums can be different from multiple sources, so the scaling comes from the Graph Min and Graph Max settings where the Aux input is configured. The dial settings only control the color bands.
