TT22 and Garmin 4x0W software
Postby Bobturner » Mon Mar 23, 2015 11:31 pm
I spoke with Trig recently, and they expect to release a software update soon that will let it accept a Garmin 4x0W series gps as a legal ADSB position source. GRT: Do you expect to add "Garmin ADSB+" as a choice for gps format, in the HX software controlling the Trig?
Re: TT22 and Garmin 4x0W software
Postby jclark » Wed Mar 25, 2015 12:03 am
I was wondering about this.
Do you know how the plan for us to make the "update"?
ADS-B+ seems to NOT work on my GNS400W+TT-22.
Plain ole ADS-B seems to work but I have not had the tests done with that yet as the install of the 400W was rather recent.
Postby Bobturner » Wed Mar 25, 2015 3:36 am
Garmin's format 'ADSB' is poorly named as it turns out it does not contain all the required data. You need to use the 'ADSB+' format which in turn requires main operating sustem V5.03 and gps operting system V5.0. If you do not have them the software is free but you may need to pay a Garmin dealer for labor.
The upgrade to the TT22 to be able to read the Garmin ADSB+ is firmware. You will need to send the box to Colorado for the upgrade. Available in a few weeks, I was told.
Finally the HX or HXr will have to be able to tell the Trig to expect to use ADSB+ format. That needs a software upgrade from GRT.
Postby ski38off » Mon Apr 04, 2016 2:20 am
Is this HXr software update in the works? Trig has released version 2.7 which includes a Garmin ADS-B+ protocol input from a GNS 4XX gps.
ski38off
Postby GRT_Jeff » Mon Apr 04, 2016 9:41 pm
It's in the November 2015 releases: HXr software version 4, HX software version 8, SX software version 12a, and Mini software version 2a. The "Garmin ADS-B" GPS Input option supports the original and the plus version if your TT22 has updated firmware.
Postby jclark » Mon Apr 11, 2016 11:31 pm
GRT_Jeff wrote:It's in the November 2015 releases: HXr software version 4, HX software version 8, SX software version 12a, and Mini software version 2a. The "Garmin ADS-B" GPS Input option supports the original and the plus version if your TT22 has updated firmware.
OOOPPPSS!!!
I thought that I had updated the Trig TT-22. I had not. I had updated the Trig TT-31 ONLY. The s/w was not ready when I wanted to do it.
So, I had to change back to regular ADS-B and **NOT** ADS-B+ for the moment.
Return to Nav/Com & Transponder
