Viewing external flight plan on Mini-X
Postby Airdog » Wed Dec 13, 2017 5:43 am
My configuration: HXr, Mini-X and GNS480.
The issue I'm having is viewing an external flight plan on the Mini-X that was entered into the GNS480 and is showing up on the external flight plan view of the HXr. The HXr handles the external and internal flight plans as outlined in the manual. However, no matter what combinations I've tried in the setup menu dealing with the Nav source, the Mini-X will not show the external flight plan off the GNS480 (again, even though it displays on the HXr). The Mini-X does handle/display the internal flight plan between the DUs just fine.
I have researched this every avenue that I can think and I am just stumped.
(PS - Note that I stated I have a Mini-X ... the HDG question I asked the other day on the -AP really was for a friend of mine! ;) )
Airdog
Re: Viewing external flight plan on Mini-X
Postby GRT_Jeff » Wed Dec 13, 2017 11:54 pm
Is the GNS480 RS232 connection wired to both? Make sure it is configured consistently as GPS1 or GPS2 on all screens.
The flight plan data comes through the RS232 connection only. If it's only wired to the HXr, make sure the HXr is configured to Send GPS Data over the link (SET MENU, General Setup, Inter-Display Link).
In the common case, where the GNS480 is GPS1 and the Internal GPS is GPS2, these settings should be set in General Setup:
GPS1 Flight Plan Source: External
GPS2 Flight Plan Source: Internal
Virtual GPS2: Off (always set to off if you have real inputs for GPS1 and GPS2)
Postby Airdog » Thu Dec 14, 2017 8:22 am
No. It's wired to the HXr, but not the Mini-X.
It wasn't. Fixed.
Mine were reversed. I swapped them to standardize.
I had those settings, but I think the obvious setting that I didn't have was the inter-display link set to pass GPS data.
All is good... external flight plan loads up fine now on Mini-X.
Thanks Jeff!
Airdog
Return to Mini B/X/AP/GA
