Resistor
PostPosted: Thu May 18, 2017 11:52 pm
by buzzglade
Received 2 resisters with sport ex. Appears one is the 301 for second pressure sender. I need 2 470 ohm resistor s one for trim one for fuel qty. What the second resister for and what rating? Can you furnish the 2 470s?
Re: Resistor
PostPosted: Sat May 20, 2017 2:10 am
You can go to a local electronics store and buy these for, about, 10 cents each.
Do you just have one fuel tank? Each sender needs its own resistor.
For a 12 volt system, 470 ohms, 1/2 watt is enough.
