SS High Pressure Sensor not setting up correctly
Posted: Wed Oct 15, 2014 3:52 pm
100 psi SS 12V Pressure Sensor not setting up as per instructions. The white wire reads 2 volts rather than 1 volt indicated on drawing (no pressure on sensor). The red wire is connected to pin 13 on EIS Connector A (regulated 12V power). When I set 2SF to 62, 2Off to 0, no pressure applied to sensor, I get an Aux display of 50 or so, rather than 20-30 mentioned in step 3.
1. Is pin 13 on EIS connector A the correct place to connect Red wire?
2. What is significance of 2 Volts on White wire rather than 1 volt indicated on drawing?
3. Suggestions?
3. Suggestions?
