During setup I lightly pressured the pitot. Every time it created an entry in the flight log.
Now I am ready to really fly, is there a way to delete these entries in the log and start over
with real flight info?
Flight Log Edit?
Re: Flight Log Edit?
Yep! The flight logs on mine are stored in the root drive of the USB. They have Demo dates on them. Delete the ones that have been created and you start over. I record every flight so I have hundreds of these on the stick. If you have a 64G stick it takes a LONG time to fill it up(depending on use).
Bert, please clarify: Did you mean the 'recording' of the entire flight, which is stored on the stick? Or the logbook page, which looks like a conventional logbook?
Bob,
Good catch didn't forgot about the logbook page....I may have given bad advice!
The manual says the logbook page has an "edit" button that lets you add stuff. Not clear, and I have never tried, to delete anything. After enough (250?) entries it will start over-writing, so eventually the un-desired entries will go away!
