Elevator Trim
Postby marvk » Tue Jul 28, 2015 2:00 pm
I can't seem to get my Sport SX to show the elevator trim. I have the trim sensor wired to the Aux. 1 wire, I can see the movement of the sensor on my EIS but the trim box is not showing on the EFIS screen. Any thoughts as to what I'm missing?
marvk
Re: Elevator Trim
Postby Bobturner » Wed Jul 29, 2015 12:23 am
Not sure, but on the HX trim displays in the same panel area as the g-meter. If the g-meter is displayed, the trim is not. Do you display the g meter? If so try changing it to display only when over 2g.
Re: Elevator Trim
Postby marvk » Fri Jul 31, 2015 10:30 pm
Tried that still no trim on screen, I can see it working on the EIS screen
marvk
Re: Elevator Trim
Postby GRT_Jeff » Mon Aug 10, 2015 11:22 pm
The Aux1 Function has to be configured for Elevator Trim in SET MENU, Graphical Engine Display. This will enable the trim box, but the arrow won't display yet. To get the arrows working, the trim input must be calibrated in SET MENU, General Setup, Flaps and Trim Calibration.
Re: Elevator Trim
Postby marvk » Thu Oct 08, 2015 5:20 pm
finally got it figured out thanks to Jeff, had a couple of things configured wrong. First and foremost was serial two was not set to EIS input, the other was I had the wrong setting in 1SF should have been 250.
marvk
Return to Sport SX
