Fuel totalizer fuel remaining - decimal/integer
The fuel totalizer fuel remaining displayed on the HXr is an integer but the entered value seems to be decimal. So when I added 35.0 gallons of fuel it is displaying 350 gallons. I can't seem to find the setting to change that on the HXr or the EIS. Does anyone know where that is configured?
Regards,
Glenn
Velocity Elite RG
Glenn
Velocity Elite RG
Re: Fuel totalizer fuel remaining - decimal/integer
Look at section 7.1.6 n the EIS installation manual and it shows how to select these.
In the EFIS you can also select digital or Interger. I thinks it's in the General men, but scroll through until you find the AUX settings and you can then select digits or intergers.
Jerry "Widget" Morris
Jerry,
Thanks, but that wasn't the problem. However, I did just find what was. The HXr is displaying the Fuel Remaining in a dial. The dial scale was set to 1. I changed it to 0.1 and now it works correctly.
Regards,
Glenn
Regards,
Glenn
Regards,
Glenn
Velocity Elite RG
Glenn
Velocity Elite RG
