Interfacing with Trig TT21 Transponder
Postby dalemed » Thu Jan 23, 2014 9:32 pm
Has anyone displayed TIS data from the TT21 or TT22 on the GRT Sport EFIS? Any tricks I should know before I make my wiring harness?
Thanks in advance for any info.
Dale
Zenith CH650B
dalemed
Re: Interfacing with Trig TT21 Transponder
Postby GRT_Jeff » Sat Jan 25, 2014 2:47 am
Configure the TT21/TT22 for Garmin TIS output, and configure the EFIS Serial Input for GTX330. The TT21/TT22 has one baud rate selection that covers both GPS and TIS, so you'll have to make sure all the baud rates match up. If you can, configure everything for 9600, the usual TIS rate. The TIS data is only provided where a TIS radar uplink still exists. It will not work in an ADS-B-only area.
Postby dalemed » Sat Jan 25, 2014 6:48 pm
Thank you! Good info.
dalemed
Postby Mel » Wed May 02, 2018 4:09 pm
Just up graded my TT21 to TT22. Sport EX controls the transponder.
Where in the menu can I input: Mode S Address, Flight ID, TIS Output, GPS System Int Level, Aircraft L&W, etc?
Mel - DAR since the last century
A&P, EAA Tech Cnslr/Flt Advsr
Specializing in Amateur-Built and Light-Sport Aircraft
<rvmel@icloud.com>
North Texas (8TA5)
RV-6 Flying Since 1993/Legend Cub purchased 12/2017
Mel
Postby Mel » Wed May 02, 2018 4:48 pm
Mel wrote:Just up graded my TT21 to TT22. Sport EX controls the transponder.
Never Mind. I found it!
<rvmel@icloud.com>
North Texas (8TA5)
Mel
Postby Bobturner » Thu May 03, 2018 1:03 am
As Jeff noted, TIS data is available only in limited areas. I'd strongly recommend putting in one of the recommended ADSB-in boxes, well under $1K.
As a side note, the TT-21 is NOT approved for ADSB-out in the US. You need the higher power TT-22 for that.
Postby Mel » Sun May 27, 2018 12:39 pm
Mid-Continent Instruments and Avionics currently offers an upgrade from TT-21 to TT-22 for $950 and includes a new 2 year warranty from Trig.
<rvmel@icloud.com>
North Texas (8TA5)
Mel
Return to Nav/Com & Transponder
