Garmin GTX327 with uAvionix Echo/SafeFly GPS/SPC
Postby Sonex1517 » Tue Mar 26, 2019 12:16 am
Until recently, my Garmin GTX327 was working fine. I used the encoder from my GRT Mini.
Now ATC says no Mode C. The 327 shows a pressure altitude and in flight I see the R illuminate when the transponder is interrogated.
Here’s what changed:
I installed an EIS-66R Remote Engine Information System, Serial Port Combiner, SafeFly GPS, and uAvionix Echo. Everything is talking, the Mini shows the EMS, and if it were a configuration issue I would expect to not see the pressure altitude on the GTX. In fact, with the Mini turned off the pressure altitude does not show up.
Any suggestions are welcome - my assumption is I did something to cause this, but I’m kind of out of ideas.
Robbie Culver
Sonex 1517
Robbie Culver
Sonex 1517
N1517S
First flight 10/10/2015
Sonex1517
Re: Garmin GTX327 with uAvionix Echo/SafeFly GPS/SPC
Postby Sonex1517 » Wed Mar 27, 2019 2:26 am
Cleaned the transponder antenna and it works. It’s always the little stuff....
Robbie Culver
Sonex 1517
N1517S
Sonex1517
Return to Nav/Com & Transponder
