Can an AUX input be put on a switch? (CS-01, CS-02)
Posted: Sat Apr 27, 2013 9:01 pm
GRT Support,
I'm configuring my EIS Auxiliary inputs (1 thu 6). Can an AUX input be placed on a switch? I have two current sensors CS-01 and CS-02 that I'd like to feed to a single AUX input #5 and make switch selectable.
Here's my current AUX input setup.
Auxiliary Input #1 Rochester Resistive Fuel Gauge (Left Tank): 30-240 Ohm
Auxiliary Input #2 Fuel Pressure (LPS-02): VDO 30psi Sending Unit)
Auxiliary Input #3 Rochester Resistive Fuel Gauge (Right Tank): 30-240 Ohm
Auxiliary Input #4 Manifold Pressure Sensor (MAP01) 5-31” 200/60
Auxiliary Input #5 Switch UP: Current Sensor (CS-01) 100 AMP (Hall Effect Sensor) - Alternator B Lead
Auxiliary Input #5 Switch DN: Current Sensor (CS-02) 50 AMP (Hall Effect Sensor) - Battery Bus (+)
Auxiliary Input #6 Power-Safe Back-Up Battery Charge Rate Monitor Output (DSub Pin 4)
Thanks for your guidance here.
Howard
Howard
