Fuel Pressure reading with engine off
Posted: Sun Apr 28, 2013 12:09 am
I have an EIS4000 with the GRT fuel pressure sensor. O-360-A1A with an Airflow Performance Fuel injection system.
When I power up the EIS it is reading 7-9 PSI before I turn on the fuel pump. When I turn on the fuel pump it appears to read normally in the 30's. Not sure what is cause the erroneous reading.
Although it did just strike my the the Airflow Performance has a fuel cutoff that is used to shutdown the engine. I also turn the fuel selector off at shutdown. Could there just be residual pressure in the system? Open for any suggestions.
