Garmin GTX327 from Mini
Posted: Fri Jun 10, 2016 10:45 pm
by Sonex1517
Is the Mini encoder output compatible with a Garmin GTX 327?
Re: Garmin GTX327 from Mini
Posted: Sat Jun 11, 2016 7:40 pm
I do not know for a fact, but certainly the Horizon (Hx, HS) encoders are compatible (serial) with the 327 because that is what I have. I'd be very surprised if the mini's encoder software was any different.
Posted: Mon Jun 13, 2016 9:52 pm
by Sonex1517
A quick email to GRT tech support confirmed it. I am just posting it here for others that have questions
>>Yes, Use an open serial port out and configure it for Fuel Air Data Z format, 9600 baud<<
What settings did you use on the GTX 327 to receive the data?
Posted: Tue Jun 14, 2016 1:29 am
set the 327 input to "FADC w/ ALT", same baud rate (9600). Exactly per the installation manual pg 9-23.
To save a port on the HX, I used a 327 serial output to send this data on to the Garmin 420W.
Posted: Tue Jun 14, 2016 2:50 am
by Sonex1517
Posted: Sat Feb 04, 2017 11:20 pm
by Sonex1517
Long overdue update - I have had my GRT Mini successfully connected to my used Garmin GTX327 for over six months.
Installing the interface was easy and quick. Great combination!
