Wiring Questions: OAT, Warning Lamp
Posted: Fri Jul 05, 2013 7:07 pm
Hi folks,
I am about to finish up a couple of wiring details and was scratching my head. The OAT probe is going in the right wing of an RV 8, near an access panel. I had originally planned to ground it locally and run the wire to the EIS. I noted in re-reading the literature, that they suggest twisting the wires and running them together. How far should I carry this twisted pair? All the way to the EIS and then pull the ground down or just behind the panel. Is this crucial? It is going to be a little bit of a challenge to run the second wire.
I had originally left the EFIS warning light off. I recent problem with a local guy not noticing that his CHT's were topping 525 (and no idiot light) led me to reconsider the idea. I understand that the warning light needs power and that the unit will send its end to ground to complete the circuit.
Should I use power from the battery bus or from the switched main power? I have a single AHRS and dual screens. Which screen should I bring the warning lamp from, the lower MFD or the upper with the artificial horizon, etc?
Michael Wynn
RV 8 Finishing
San Ramon, CA
Michael Wynn
RV 8 Finishing
San Ramon, CA
