Fuel Consumption (not Flow) + RPM
Posted: Tue Jun 20, 2017 8:58 pm
I have both the 6000 EIS and the HXr:
The ULPower 520is reports four fuel consumption outputs which are not related to the fuel flow rate. These reports are, one per ECU (and there are two ECUs):
Fuel consumption (Injector pulse): Output is a duty cycle. 100% is equal to 72l/Hr.
fuel consumption (pulses/litre): 72l/Hr = 170Hz (170 pulses/sec).
Here is the RPM:
RPM signal (3 pulses/ rev. 0 – 9V)
Where should these be connected on either the HXr (I have two) or the EIS, and which is preferred as the input type?
Here is the RPM:
