Will 8.4" fit in Sport HS hole
Grahcm
Post by Grahcm »
Hi all,
I am thinking of upgrading from a Sport HS, to a 8.4 inch Hxr. I would like a drop in mechanical replacement. I understand I will have to redo the wiring. Does the 8.4 Inch Hxr have the same hole placement as the Sport HS?
thanks
Geoff
Re: Will 8.4" fit in Sport HS hole
Yes, if you have an 8.4" HS. The cut-out and screw holes are the same for the 8.4" HXr and Sport HS 8.4".
