USB GPS
Postby Clam » Mon Mar 23, 2020 2:16 pm
I have a USB WAAS GPS left over from an Open Flight Solutions FlightBox device. Was wondering if a USB GPS device like this can be read by the HXr system through a USB port, and if so, any guidance for set-up. I currently keep a USB drive in one USB port for data/logbook download and a bluetooth dongle in the other USB port.
If this device will provide the HXr with GPS data, could I add a 2 port hub to one of the HXr ports, or would it need to directly into one of the 2 ports?
Thanks.
Jeff
RV-8 Memphis, TN (KFYE)
jb.flynavy@gmail.com
Clam
Re: USB GPS
Postby Bobturner » Mon Mar 23, 2020 7:15 pm
I use a Skyradar D2, with its own gps, to feed adsb-in data to my Hx via USB. The Hx does see the gps data (I labeled it gps2). So it is possible.
Re: USB GPS
Postby Clam » Tue Mar 24, 2020 2:39 am
Thanks Bob. Thought I might as well plug the little bugger in and see what happens as it is just gathering dust on a shelf. Maybe it'll come in handy when my Garmin 430W goes on the blink. Nevermind that in 10+ years the 430W hasn't so much as farted even once. My ADS-B in is via FlightBox but I used their serial connector to the HXr and also Wi-Fi it to an iPad mini.
Jeff
Clam
Re: USB GPS
Postby GRT_Jeff » Wed Mar 25, 2020 5:35 am
We haven't programmed the EFIS to look for plain GPS data on USB inputs. The EFIS currently only looks for ADS-B receivers and XM WX receivers on USB, and only when those are turned on in General Setup.
Re: USB GPS
Postby Clam » Wed Mar 25, 2020 1:06 pm
Ah, ok. Then since I have the ADS-B in wired to a serial pin, I will attempt to have HXr utilize the GPS portion of that stream through serial, as Bob is doing through his USB. Thanks, that saves me some time.
Jeff
Clam
Return to IFR GPS
