Flight plan format
Posted: Fri Jul 03, 2020 6:12 pm
by TONYBISHOP
Like many flyers in Europe, I use SkyDemon on an iPad for navigation. I don't expect you support either iPad or SkyDemon, but could you publish your flight plan format, and enable us to input a FP file via the USB stick?
Many thanks, Tony
Re: Flight plan format
Posted: Thu Jul 09, 2020 3:39 am
Our internal flight plan function can import a flight plan into the active sequence plan from a standard GPX file on a USB stick. It will accept a route or just a list of waypoints in order. This is the "Import" function on the flight plan page.
Posted: Sat Feb 27, 2021 10:42 pm
by rv8ch
Jeff, do you have an example that shows how to import a plan that uses identifiers already in the system, like airports? I don't want to create waypoints, just use what's already there. Thanks!
Posted: Tue Mar 02, 2021 12:44 am
rv8ch wrote: Sat Feb 27, 2021 10:42 pm
You have to specify the coordinates anyway. The EFIS will try to match them up with something already in the system, otherwise it will just create a temporary waypoint as part of the plan. Here is a very minimal example of two waypoints that are also in our US database. VIO is a local VOR and 08C is a local airport.
Code: Select all
<gpx>
<rte>
<rtept lat="42.786716" lon="-85.497070">
<name>VIO</name>
</rtept>
<rtept lat="42.936722" lon="-85.805756">
<name>08C</name>
</rtept>
</rte>
</gpx>
Posted: Wed Apr 14, 2021 10:41 am
by rv8ch
Thanks, can the EFIS import <trk> and <trkseg> as well as <rte> and <rtept>?
I found a tool that will format my Foreflight FPL file as GPX, but it puts out <trk> like this:
Code: Select all
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<gpx xmlns:gpxtpx1="http://www.garmin.com/xmlschemas/TrackPointExtension/v1" xmlns="http://www.topografix.com/GPX/1/1" xmlns:trp="http://www.garmin.com/xmlschemas/TripExtensions/v1" xmlns:gpxx="http://www.garmin.com/xmlschemas/GpxExtensions/v3" xmlns:gpxtpx="http://www.garmin.com/xmlschemas/TrackPointExtension/v2" version="1.1" creator="RouteConverter 2.29">
<metadata>
<time>2021-04-14T08:20:14.584Z</time>
</metadata>
<trk>
<name>LSGY TO EDNY</name>
<trkseg>
<trkpt lat="46.761944" lon="6.613333">
<name>LSGY,Airport</name>
</trkpt>
<trkpt lat="47.13" lon="7.2297222">
<name>VP067,Intersection</name>
</trkpt>
<trkpt lat="47.181389" lon="7.416389">
<name>LSZG,Airport</name>
</trkpt>
<trkpt lat="47.183056" lon="7.741667">
<name>LSPL,Airport</name>
</trkpt>
<trkpt lat="47.092153" lon="8.304847">
<name>LSME,Airport</name>
</trkpt>
<trkpt lat="47.171667" lon="9.039444">
<name>LSZX,Airport</name>
</trkpt>
<trkpt lat="47.7183333" lon="9.4233333">
<name>VP003,Intersection</name>
</trkpt>
<trkpt lat="47.671317" lon="9.511486">
<name>EDNY,Airport</name>
</trkpt>
</trkseg>
</trk>
</gpx>
Posted: Fri Apr 16, 2021 4:16 am
No. It looks like trk/trkseg is a generic way to record past positions. It's very close though. If you change trk to rte, remove the trkseg tags, change trkpt to rtept, and remove the type/purpose from the name tags (the name should be just the identifier, "LSGY" not "LSGY,Airport"), then it would work.
What does the FPL file look like?
