Fuel Flow sensor issue
Posted: Sun Jun 04, 2023 1:58 pm
After installing everything I had my Red Cube sensor working as well and was planning to start calibration when it suddenly died on my last flight.
I had the black box recording going and it looks like it just died within about 20 seconds - went down all the way from 11 gallons ( which is btw wildly inaccurate for my Rotax 912 ULS but that's beside the point - as I mentioned I have not had chance to calibrate it yet)
I was doing touch and goes and on increasing power to 5300 RPM ( the go part ) it went up to 11 gallons and then went down to 0 within 20 seconds and never recovered ( the csv file is attached )
Here is the relevant part - fuel flow and RPM - you can see RPM being constant at 5300 or so while fuel flow dropping to 0.
Reading the troubleshooting guide for IES, to me it suggest a blocked fuel flow sensor rather than anything else but I am not sure - should I even bother checking electrical connections or does it sound like blockage problem ?
Code: Select all
7.6 5290
9.3 5250
11.1 5250
9.7 5240
7.4 5240
5.7 5250
4.3 5250
3.3 5250
2.5 5260
2 5260
1.5 5260
1.1 5280
0.9 5280
0.7 5280
0.5 5280
0.4 5290
0.3 5290
0.2 5300
0.2 5300
0.1 5310
0.1 5310
0.1 5320
0.1 5300
0 5300
0 5300
0 5300
0 5320
0 5320
0 5330
0 5340
0 5350
