Hall Effect Current Sensor settings
Posted: Sun Mar 30, 2025 5:16 pm
I've searched the forums and read the Hall Effect Current Sensor documentation, and I still haven't found my answer:
What are the correct settings for Aux Scale Factor and Offet to sense 0 to 100 amps with the sensor mounted on the alternator output cable (no negative sensing needed.)
With no modifications to the input I am seeing 1.2 amps indicated, changing slightly as I turn high-current equipment on and off (landing lights, pitot heat.) I should be seeing in excess of 10 amps with these items on.
New RV-10 with dual Horizon 10.1 screens and remote EIS
