L2E "Timing Advance" settings
Posted: Sun Mar 30, 2025 5:35 pm
What are the correct settings for Aux Scale Factor and Aux Offset for Timing Advance using the L2E interface on my Lightspeed Engineering Plasma III ignition? According to the L2E documentation:
"The L2e outputs a 0-5 volt signal to be connected to a compatible input on your EFIS engine monitor.
Scale your EFIS as specified below:
Timing Advance: 0.1 volts per degree of advance (example: 2.5 volts = 25 degrees of advance)"
Thus I need to scale the Aux Input to show 0 - 46 degrees of timing advance from an input of 0 - 4.6 volts.
