Safety Concern- Near Midair
Posted: Sat Apr 05, 2014 12:36 am
by gbrasch
Long story short, flying along at 8500' under ATC control. Have 2 targets showing in my area overlapping each other (Nav Worx unit). Display on one shows several thousand feet below me, covering up the other target. Then that target drops off showing the underlying target at my exact altitude. I look in that direction and at my 2 o'clock is an aircraft within 300 feet of me coming straight at me, now doing an evasive maneuver. Never a traffic alert from ATC (ABQ Center). Programers, is there some way with overlapping targets to make the target closer to our altitude show first? Thanks in advance. Glenn
Re: Safety Concern- Near Midair
Posted: Sat Apr 05, 2014 1:13 am
What GRT EFIS are you using? The HX or HXr should have showed the close-in traffic on the PFD display, over top of the AI.
Just a reminder: unless you are in class A or B airspace ATC is not responsible for traffic separation. And, until 2020, there are no guarantees with ADSB, either.
Posted: Sat Apr 05, 2014 2:58 am
by revenson
I thought traffic only showed on the map pages. Anyway, the original comment is still a good one. It's not about liability but clarity.
Posted: Sat Apr 05, 2014 3:55 am
by gbrasch
Bobturner wrote:What GRT EFIS are you using? The HX or HXr should have showed the close-in traffic on the PFD display, over top of the AI.
I have the Sport SX and was in the Map Mode. And I realize it is my responsibility to "see and avoid", not my point, just a safety suggestion to the programmers to see if there is a potential fix.
Posted: Sat Apr 05, 2014 4:21 pm
by 330drvr
You also can go into the GRT settings and specify that traffic only plus or minus such and such altitude will be displayed. I use +/- 1500 feet, so I don't get bogged down by traffic 5000 feet above me (who cares).
I don't know if the Sport does this, but the HX displays traffic on the PFD as well which would help you discriminate the most serious threat.
Posted: Sat Apr 05, 2014 4:31 pm
by gbrasch
330drvr wrote:You also can go into the GRT settings and specify that traffic only plus or minus such and such altitude will be displayed. I use +/- 1500 feet, so I don't get bogged down by traffic 5000 feet above me (who cares).
Very helpful, thanks. I need to find out if the Sport will do that, not sure.
Posted: Mon Apr 07, 2014 9:25 pm
We probably could sort the traffic by altitude. I will look into it.
All displays have the "Traffic Altitude Filter" in SET MENU, General Setup.
Posted: Tue Apr 08, 2014 2:05 pm
by 330drvr
Since we are on the subject, I will again put a pitch in for a distance filter to work in conjunction with the traffic filter. I think showing traffic more than say 10 miles away is a serious distraction and also tends to cover up map details. I do thank you for the altitude filter. I use +/- 1500 feet. The Navworx software used to have both of these filters but for some reason was removed in later software. I have suggested to Navworx to restore them in a future revision.
