Analog inputs
Analog inputs
Can a simple linear pot be used as a sensor for flap or trim position? If so what is the recommended value? I understand that the HX unit has a pull up that can be turned on so no voltage needs to be applied to the sensor device.
Re: Analog inputs
The simple answer is yes. The linear variable resistor units from Ray Allen work well, no external bias needed. I think they are a few Kohms max.
Re: Analog inputs
Does anyone know the resistance value of these pots?
Re: Analog inputs
Ray Allen units are 0 to 5 K.
