Time frame and features of the next HX release?
n468ac
Post by n468ac »
Re: Time frame and features of the next HX release?
We're working on finishing it up this week. Here are the most significant features:
  • Add SVE AGL function to show height above ground based on Synthetic Vision database
  • Add the ability to use the GPS attached to an ADS-B receiver as GPS1 or GPS2
  • Add Enroute HITS. This version requires coordinates for the origin and destination of the leg and draws boxes along the course between them.
  • Show compass ring on the NORTH UP map
  • Show tapes on NORTH UP map if enabled
  • Add ADS-B TFR's
  • Add ADS-B call sign on traffic symbol
330drvr
Post by 330drvr »
ADSB TFRs. Super!
RV-7A
n468ac
Post by n468ac »
Can't wait! thanks for the preview
akskyhawk
Post by akskyhawk »
The new release is suppose to have the ability to have a com radio input on a serial input so that a person can have dual coms with a HXr system per Greg & Todd so that my system will work!!
Bavafa
Post by Bavafa »
Wow, excited for the TFR from ADS-B, can wait for this new version.
n468ac
Post by n468ac »
release this week?
n468ac wrote:release this week?
I suspect that you can expect goodies real soon.
Bavafa
Post by Bavafa »
I up loaded the new software and now I see my own shadow as traffic. I have had my flight ID (N# and Mode S address) previously added and also confirmed that is still there but I see myself as a traffic. In a 40 minute flight today, this did not happen 100% of the time but many time and mostly when there were other traffic around. I also did not see any N# on other traffics but that simply could be that they were all mode C traffic and not ADSB-out
Is there any other settings that need to be changed for my own shadow not to be displayed?
Here is some details about my setup
ADS-B out is thru GTX330 ES
ADS-B in is skyradar D2
I see my Flight ID (both N# and Mode S) in the setup page
I had my IPAD with WINGX
My shodow does not show up all the time by a good portion of the flight (both on map and PFD
I wonder if any one else sees this issue?
Mehrdad
Are you saying your "own ship" was suppressed before the upgrade, now it is not?
Are you feeding the HX TIS (traffic) from both the transponder and the Skyradar? I saw in another reply from GRT that the Trig transponder TIS info does not have ID's attached. I have no idea what comes out of the 330-SES. Did you check that the 330 is still sending out the correct mode S ID and N number? (not sure how that could have changed).
When you see your ghost is your N number attached?
