Min Fuel Setting
Postby JimB » Thu Nov 27, 2014 9:15 pm
I have Sport HS EFIS and EIS. My in tank fuel quantity sensors are Aux inputs on the EIS and vary between 0 and 100. In my EFIS the in tank fuel quantities are Aux 3 and Aux 4. I have fuel calibration tables enabled which convert the 0 to 100 from the EIS to 0 to 20 gal on the EFIS. I think the way to get a minimum fuel quantity warning based on the in tank sensors is to set the Aux 3 and Aux 4 minimum values on the Engine Setup Page. But do I set them for 2 gallons or do I set them for 30 which is the EIS value for 2 gallons?
I also have the fuel totalizer option which I understand is independent of the in tank sensors and I have minimum fuel warning working there.
Europa XS Rotax 914
JimB
Re: Min Fuel Setting
Postby GRT_Jeff » Mon Dec 08, 2014 8:54 pm
The limits in the SET MENU, Engine Limits page apply after the table corrections, so you would set them to 2 gallons.
Return to Sport SX
