It appears that in the newest "Horizon HX Wiring Supplement" (for units shipped after January 8, 2013), all references to the Warning Light Output (pin 1 of Connector B) has been removed.
Is this function no longer available in the newer units?
Thank you for in advance for responses.
-Buck
HX Warning Light Output
Buckeroo18
Re: HX Warning Light Output
I don't know why all of those pins are listed as NC. The hardware has not changed and all of those pins still work as in the older documentation. I'll have someone review it.
That is interesting. I turned off all the analog ILS inputs after I installed the HX's to replace the WS's since I believed those connections were no longer operable. The ARINC 429 connection works perfectly of course so it has caused no problems.
RV-7A
