Altimeter Calibration for EFIS2/AHRS2 - won't initiate calib
Posted: Sun Apr 26, 2015 11:42 am
Guys,
I recently calibrated my altimeter on my EFIS HX dual display using instructions in Chapter 9, section 9.1.1 of the user manual. I'm on EFIS SW version 6c, and AHRS SW version .43. I have a dual AHRS system.
I have a difference in altimeter readings between the two EFIS displays that I'd like to correct. In trying to use the Altitude calibration procedure on the 2nd EFIS (MFD), I switch to AHRS2 on the bottom menu, and initiate the calibration to (Initiate) ON...but nothing happens. The display just goes back to Altimeter - Calbration OFF in the calibration setting.
Anyone run into this? What am I doing wrong here? The same sequence of process steps worked fine when calibrating AHRS1 on EFIS1.
Howard
GlaStar, N19HL
Howard
GlaStar, N19HL
