EIS 4000 /10-180 ohm fuel sender compatability
wrigh017
Post by wrigh017 »
The EIS 4000 installation only mentions 240-30 ohm resistive fuel senders. Can the aux inputs for fuel level be made to work with 10-180 ohm senders?
Re: EIS 4000 /10-180 ohm fuel sender compatability
Yes. 10-180 will work the same as 250-30.
Ben knox
Post by Ben knox »
Will capacitance senders work with eis 4000
Any sender with a linear output in the 0-5V range will work. The EIS aux inputs are 5V max. A voltage divider could be used if the voltage is higher.
