ADS-B Strautx
Postby sonex569 » Mon Jan 18, 2016 6:14 pm
Have a Sport H and building a Stratux which will be serial out (I hope). May I use a banana plug on panel to connect to serial port?
Regards
Dick
sonex569
Re: ADS-B Strautx
Postby Bobturner » Mon Jan 18, 2016 6:28 pm
Personally I wouldn't use a banana jack, I think after a while they lose their snugness and plugs just fall out. But I think it would work, especially at lower baud rates. Make sure there's a ground return. If the run is more than a couple of feet I'd use shielded cable, but again that may be overkill.
Re: ADS-B Strautx
Postby sonex569 » Tue Jan 19, 2016 5:48 pm
Well I might better hard wire it in. Can always pull the pin out of DMB connector.
Regards
sonex569
Return to Sport SX
