I have had my Sport HS EFIS providing altitude information to my GNS430 and GTX327 using the Fuel/Air Data Z Format for many years.
I have now replaced the GTX327 with an Appareo ESG transponder. It does not accept the Fuel/Air Data Z Format. I found that if I use the Trimble/Garmin encoding altimeter output of my EFIS, the ESG will function correctly. However that required that I change the altitude input format on my GNS430 to Icarus-alt. (the wiring from the EFIS splits to the GNS430 and the transponder).
I think the GTX327 needed air data to obtain GPS information primarily to know when the aircraft is in motion to switch from STBY to ALT mode. Since the ESG has a built in GPS, all it needs is altitude data. I think the same can be said of the GNS430, it only needs altitude data and not GPS or pitot airspeed data.
I think this is OK but would like confirmation.
Jim Butcher
Altitude Encoding
Re: Altitude Encoding
The GNS430 can use the airspeed, wind, and fuel information in the Fuel/Air Data message, mainly for flight planning and display. The airspeed information is also provided in the ARINC-429 connection.
Note you can use the "Serial--trim/gar-25 ft" (higher resolution) setting in the Stratus.
Small note: As of a few years ago the FAA recommended procedure is to turn auto-switching off; run the transponder in ALT mode whenever the engine is on.
Thanks Jeff and Bob. It looks like I will be fine as I have it configured.
This information would be useful in the GRT Equipment Supplements document. I had no idea that my GRT would have the accuracy to use the higher resolution setting in the ESG.
Jim Butcher
Jim Butcher
