Westech Fuel Sender Setup
Posted: Wed Oct 17, 2018 6:08 pm
by bd4c
Is there anything in particular in the EIS or EFIS I need to do in order for the fuel sender to work / be interpreted correctly?
Sender: Westech; spec link below.
https://ln.sync.com/dl/d91eac7e0/jemswi ... j-epf9x77m
Re: Westech Fuel Sender Setup
Posted: Thu Oct 18, 2018 12:37 am
You have to set the scale factor and offset like with any other fuel sender.
If it is the kind that outputs 0-5 volts, then this is easy. You can wire the output directly to the aux/analog input (no resistors or excitation voltage). Set the scale factor (SF) to half the capacity of the tank (or the calibrated capacity of the sender) for integer mode (no tenths). If you want to display tenths, then set the scale factor to half the capacity times ten and use decimal mode. Set the offset (OFF) to zero. If it reads the wrong direction, flip the sensing mode in the EIS/EFIS between forward (+) and reverse (-).
If it is the kind that varies by 240-30 ohm, then you can connect it and calibrate it the same as a float sender. If the full/empty resistance is precalibrated, you may be able to compute the scale factor and offset values without moving fuel around.
Posted: Thu Oct 18, 2018 2:39 am
by bd4c
So, for a tank with a capacity of 26 gallons, the scale factor would be entered as "13"; correct?
Posted: Thu Oct 18, 2018 10:26 pm
Yes. This would cause the EIS/EFIS to compute 26 gallons (no decimal point) at 5V.
