Oil Pressure sender ground
Posted: Fri Jan 24, 2014 9:17 pm
"Ground is normally provided by the engine when the sensor is mounted directly to it, but a separate ground wire may be necessary for remote installations", says the EIS manual in paragraph 5.2.4 for installation of the VDO oil pressure sender.
Can I get a little more detail on how the separate ground wire could be added?
Thank you, Eric - installing an EIS 4000 on an O-320 Lycoming
