Move Traffic Box Slightly in HX
Posted: Sun Feb 23, 2014 3:55 am
by revenson
When flying near another airplane (in formation), the traffic popup box stays up, even though I am aware of the traffic. The problem is that the traffic box covers the airspeed tape. While I can see my numeric indicated airspeed, I'd also like to see the ribbon. I can't see how close I am to the yellow (caution range) or redline when the ribbon is covered by the traffic box.
I'd like to be able to turn off the traffic box in the above situation, or at least I'd like to see it moved over slightly to allow viewing the airspeed tape.
Re: Move Traffic Box Slightly in HX
Posted: Sun Feb 23, 2014 5:51 am
In the set up menu you can turn the pop ups off. Or turn adsb off.
Posted: Sat Mar 01, 2014 1:33 am
The position of the pop-up is a compromise to show the current airspeed without covering too much of the map. When you're flying in formation it's probably best to turn off the pop-up with the SET MENU, Moving Map, Traffic Alert Window setting.
Posted: Tue Mar 04, 2014 8:50 pm
by 330drvr
If formation flying, I would suggest the wingman squawk standby.
Posted: Wed Mar 05, 2014 2:13 am
by jclark
330drvr wrote:If formation flying, I would suggest the wingman squawk standby.
Actually, if you are a WINGMAN, you should have no idea/no worry as to airspeed or altitude.
On the other hand, if you are LEAD, then those items are critically important and you are most likely the one that has transponder squawking.
Posted: Wed Mar 05, 2014 3:07 pm
by 330drvr
I guess I wasn't clear. That is the whole point of course. You don't need two transponders in a formation. With only one operational, you don't get the traffic popup on the lead's screen.
