Low Voltage
Posted: Thu Aug 14, 2014 3:25 pm
by Rob Henderson
I have an HXr and the voltage has always read low.
I removed the display and made a new harness to test all 3 inputs with a battery.
The voltage read with a Fluke meter was 12.6 but the HXr showed 12.2 on all three inputs
This seem like a lot of error, Is this normal?
-Rob
Re: Low Voltage
Posted: Fri Aug 15, 2014 2:19 pm
by jclark
No.
Sounds normal to me.
The units have diodes (and probably other stuff) inside to make it possible for them to be feed from multiple power sources.
A .4 volt drop across a diode is not out of the ordinary.
Press on!
Re: Low Voltage
Posted: Fri Aug 15, 2014 4:30 pm
I disagree, mine reads correctly. It should be no worse tham 0.1 volts error.
Before calling GRT check all power AND ground connections.
Re: Low Voltage
Posted: Sat Aug 16, 2014 1:58 am
by jclark
A question of clarification ...
Bob,
Are you saying that you are seeing only .1 volt difference in the EFIS V1, V2,V3 and actual battery voltage????
I need to go back and check mine as I *think* that mine has always been a lot bigger difference.
Not disputing. Just checking to verify.
Re: Low Voltage
Posted: Sat Aug 16, 2014 1:21 pm
by jbasol
I have found the same thing with my HX system. The voltage measured by any of the EFIS inputs is always .3-.4V lower than what the EIS reads. The EIS happens to agree with what my DVM shows at the fuse block, so that's the one I pay attention to.
-John Basol
Re: Low Voltage
Posted: Sat Aug 16, 2014 5:37 pm
Curious. I have an Hx, EIS, and other brand D6. The Hx is on the avionics buss, the other two are not. All three agree within 0.1 volts if I turn off all other avionics. If I turn on the usual avionics I see that buss drop 0.1 or 0.2 volts. I figure it's a small resistance across the CB.
Re: Low Voltage
Posted: Tue Aug 19, 2014 7:54 am
If you have a long harness and the HXr screen is at full brightness, you will see a voltage drop just because of the current through the wires. The backlight uses a lot of power. The voltage drop will decrease when you reduce the brightness of the screen.
