I was looking over the data from first flight and didn't see anything in the fuel burned column.
I had good fuel flow showing.
What do I need to do to get and show how much I have burned during and after a flight?
Bert
Fuel Total Used?
Re: Fuel Total Used?
I'm not sure there is a 'fuel used' function. But there should be a 'fuel remaining' one. Is your display configured to show this?
Bobturner wrote:I'm not sure there is a 'fuel used' function. But there should be a 'fuel remaining' one. Is your display configured to show this?
Yes, Bob, on the "scoreboard" of the HXr, there is a "USED" for the amount of fuel since startup on this flight.
Bayou Bert
James, how to reset? When does it go to zero for next flight?
Do I have to reset, if so, how?
Bert
Bert
The fuel used should increase as long as fuel flow is working. It will automatically reset to zero the next time the system transitions to "in-flight" mode when airspeed passes 30 knots IAS.
