Garmin GTX327 from Mini
Postby Sonex1517 » Fri Jun 10, 2016 10:45 pm
Is the Mini encoder output compatible with a Garmin GTX 327?
Robbie Culver
Sonex 1517
N1517S
First flight 10/10/2015
Sonex1517
Re: Garmin GTX327 from Mini
Postby Bobturner » Sat Jun 11, 2016 7:40 pm
I do not know for a fact, but certainly the Horizon (Hx, HS) encoders are compatible (serial) with the 327 because that is what I have. I'd be very surprised if the mini's encoder software was any different.
Postby Sonex1517 » Mon Jun 13, 2016 9:52 pm
A quick email to GRT tech support confirmed it. I am just posting it here for others that have questions
>>Yes, Use an open serial port out and configure it for Fuel Air Data Z format, 9600 baud<<
What settings did you use on the GTX 327 to receive the data?
Robbie Culver
Sonex 1517
N1517S
Sonex1517
Postby Bobturner » Tue Jun 14, 2016 1:29 am
set the 327 input to "FADC w/ ALT", same baud rate (9600). Exactly per the installation manual pg 9-23.
To save a port on the HX, I used a 327 serial output to send this data on to the Garmin 420W.
Postby Sonex1517 » Tue Jun 14, 2016 2:50 am
Robbie Culver
Sonex 1517
N1517S
Sonex1517
Postby Sonex1517 » Sat Feb 04, 2017 11:20 pm
Long overdue update - I have had my GRT Mini successfully connected to my used Garmin GTX327 for over six months.
Installing the interface was easy and quick. Great combination!
Robbie Culver
Sonex 1517
N1517S
Sonex1517
Return to Nav/Com & Transponder
