Panel Tilt
Postby MustangUSA » Sat Jun 25, 2016 9:03 pm
Hi Group,
I have just started the process of programming my new Sport SX 200A.
On page 4-23 of the install manual... it says to go to the "Set Instrument Orientation"
Obviously, there is no line item called that exactly, in the AHRS Maintenance section.
What line item selection do I use/goto to enter the initial panel offset degrees?
Thanks in Advance,
John Wanamaker
EarthStar JT2 N701SY
Cuyler Airpark (FD27)
MustangUSA
Re: Panel Tilt
Postby GRT_Jeff » Tue Jun 28, 2016 5:10 am
If you have a Sport SX with Adaptive AHRS, the line item is "Set AHRS Orientation" at the end of AHRS Maintenance, a couple lines before "Load AHRS Software". After changing the AHRS pitch (or roll), you should then use the "Set Magnetometer Orientation" menu to align the magnetometer with the new AHRS orientation.
Re: Panel Tilt
Postby MustangUSA » Tue Jun 28, 2016 10:06 pm
Thanks Jeff,
I looked at that initially before I posted the first message. Thanks for confirming.
I am on a major learning curve here... and I only want to make as few errors as possible. <G>
MustangUSA
Return to Sport SX
