Anyone running a SL-30 and 400W/500W with their Mini
Postby recapen » Thu Dec 15, 2016 5:06 pm
I'm looking for specific config info.
I have the ARINC converter hooked up along with the Magnetometer.
My 420W uses the ARINC for GPS along with one of the serial ports for Aviation data (from 420W only)...seems to work fine - will be upgrading to a 430W soon (hopefully this weekend).
My SL-30 uses one of the serial ports (bidirectional)...I can see the freqs (NAV and COM) from the SL-30 - but can't get the OBS to work.
I just want to make sure I have the settings correct - from someone that has done it.
recapen
Re: Anyone running a SL-30 and 400W/500W with their Mini
Postby Bobturner » Thu Dec 15, 2016 8:30 pm
Unfortunately my settings are out at the airport (this is SL30 to HX). I do recall that the SL30 settings had to be something specific, too. Have you also configured the SL30?
Postby GRT_Jeff » Fri Dec 16, 2016 3:24 am
For the SL30 OBS to work, the INDICATOR HEAD TYPE in the SL30 configuration must be set to SERIAL or NONE.
SERIAL - The SL30 accepts and requires a remote OBS serial command for the OBS to work. No other OBS inputs are accepted.
NONE - The SL30 will accept remote OBS serial commands as long as it's receiving them. You can use the knob on the SL30 to set the OBS if the serial command is not received.
Postby recapen » Fri Dec 16, 2016 5:42 pm
Already set for Serial - had it that way to interface with my AFS3400.
recapen
Postby recapen » Sun Dec 18, 2016 1:53 pm
Looks like the SL-30 is working OK - I needed to set it to #2.
Having issues with the 430W side still though. I did the "Post-Installation checkout for ARINC 429 and GNS430" from the supplements page.
Still not clear on the 430W settings on the Mini-AP side though.
recapen
Return to Mini B/X/AP/GA
