Audio & discrete outputs
MolsonB
Post by MolsonB »
On the HXr, Audio Out Hi is pin B24. Is there an Audio Out Lo?
Hooking up to PS-Eng PAC15EX
And I'm guessing the 8 discrete outputs are A6 - A13?
Re: Audio & discrete outputs
On some units B25 is audio low. Otherwise use any ground.
On every HX and HXr, B25 is audio ground.
The 6 discrete outputs are B8 through B13. See the attached older connector document (it is still accurate for all HX and HXr).
HX Display Unit Connector Definitions Rev A.pdf
(73.14 KiB) Downloaded 1324 times
MolsonB
Post by MolsonB »
Ah look at that. Perfect. Haven't seen that doc before. Weird how it never got transferred over to the new documents.
Thanks Jeff for the info.
