I have 1,000 hours on this installation of (3) HX systems and a TT AP in an RV10. This problem occurred sporadically in the past and is only noticeable in calm air. Now it's a constant problem in calm air.
When HX is driving TT AP it constantly banks left and right. It seems to be hunting for the exact track and ends up deviating a degree or 2 left and right for the duration of the flilght in calm air. This occurs whenever the TT is in LS or NAV mode. To mitigate the problem, I allow the HX to get the AP on course and at the right altitude, then switch the AP into 'native mode' where it navigates using its internal guidance. The immediately stops the banking.
I've played with some of the HX settings but need some advice. Please help
- BillinDurham
Bill Watson
8NC8 Durham, NC
RV10 (1) HXr, (2) HX, IFD440, TruTrack AP, TT22 Tpx, UAvioni echoUAT, (2) Surefly SIMs, EIS
8NC8 Durham, NC
Re: When HX is driving TT AP it constantly banks left and ri
The "NAV" mode usually means the native serial GPS flight plan mode of the TT. Do you mean it works in the serial GPS flight plan mode but not when using the ARINC-429 steering?
There could be some data that's moving around a little, like the magnetic heading, due to noise or interference. We might need a DEMO recording of the behavior to see if we can find the cause.
Have you tried reducing the roll gain? This sounds like a settings issue. I have a Trio and it is rock solid, but it probably uses different settings than the TruTrak.
- BillinDurham
I have played with the HX steering gain but not recently. I'll try some extremes and see what I get.
Regarding the various modes:
There is 'full function 2 axis HX driven mode' where the TT AP displays "EXT LS GS". I assume that is ARINC driven and it is full GPSS steering mode.
There is 'steering-only mode' where the TT AP displayd "NAV". The HX is still driving it but only lateral steering and not GPSS steering mode. That is, it flies to and over waypoints rather than anticipaing them. I'm guessing that it is a serial feed.
In both of the above modes, I get the wing rocking.
There is 'TT native mode" where the AP flies whatever track and climb/descent rate I select. No wing wagging here.
I did get an HX recording and some camera shots but having some trouble finding and organizing them so I'll do that again. Any suggestions on exactly what to do are welcome.
Bill Watson
8NC8 Durham, NC
8NC8 Durham, NC
- BillinDurham
Re: When HX (now HXr) is driving TT AP it wing rocks
I had to step away from this issue due to some other electrical issues but the problem persists despite a HXr upgrade.
(after posting this it occurred to me that this would best be posted under Autopilot. So a new single post is now posted there with a summary of notes from this thread)
There is one more data point to be considered: I have a switch that changes the ARINC input between the HX/HXr and direct input from the G430w. When connected to the HXr, the wing rocks. When getting the GPSS signal directly from the G430w, steady as a rock. Obviously in that mode I lose the vertical navigation function and the ability to control the Trutrak with the EFIS.
Please review the previous posts for more observations - all of which are still valid. The only difference is that the TT AP is connected to an HXr rather than an HX.
Next flight, I will document this behaviour with a video camera where it is very easily viewed. I can do a demo recording as well. The question is what else can I do to document my installation and the behavior?
- Is there a way to view or printout the settings from a backup file?
- How can I return all relevant settings to the defaults without effecting other settings?
And does anyone have a TruTrak - HX - G400/G500 installation where there is no wing rocking in GPSS mode? If so, can you share the settings.
Any and all advice welcomed.
1100 hours and flying...
Bill Watson
8NC8 Durham, NC
8NC8 Durham, NC
