I noticed in the voice alert pack that there is an alert for 'Landing Gear".  I can find no documentation on setting up such an alert though.  Can someone point me to the documentation for this?
-John Basol
						Landing Gear Voice Alert
Re: Landing Gear Voice Alert
If you need an alert for Lansding Gear right now, here is what I **think** you need to do.
create a .wav file named "alarm0124" and in it put the message ( your ".wav" file of whatever you want said about the gear).
I would expect that further documentation will be forthcoming as it gets further testing.
If this does not work at the moment, please do NOT hold me responsible.
Hope this helps.
Hope this helps.
And so after naming said file as you describe, it is automatically played when what input is triggered?  In other words how is it going to know that Analog 8 is my gear warning?  I can find no documentation that says "name your input as such", or "set your gear warning input here".
I think that I was WRONG.
I think that I made a mistake.
Will research more and report back.
Sorry about that.
Sorry about that.
The landing gear alert was added for future use.  It is not currently triggered by anything.
Is there a way to trigger this alert yet?
-John
						-John
Any update on triggering the Landing Gear voice alert?  It would be a great safety add.
-John
						-John
+1 for an answer.  I have a Horizon 10.1 and was hoping there was a way to configure the analog port settings so it triggers an aural voice alert when a certain parameter is set like airspeed.  For example, entering a 'trigger' airspeed value (e.g. 50 kts) into the setup menu and assigning an analog port to receive voltage from one of the landing gear sensors/gear indicator lights.  Fly below that airspeed + no sensed voltage = aural alert/warning.
Is this possible? Or at least available in the near future?
We have had many requests for landing gear alerts recently so I have moved it up the priority list as the next feature to work on.  We are currently working on some production issues and then we can get back to that.
Hi Jeff,
I noticed last year that 8.02 beta 5 mentioned initial support for landing gear indication, any chance that's getting closer to functional?
-John
-John
