Checklist Accept for Aux input
dalewilley
Post by dalewilley »
I noticed that a checklist accept is an option for an aux input. What is the input expecting to see to make this work? Ground or a voltage?
Thanks Dale
Re: Checklist Accept for Aux input
An Analog Input on an HXr or 10.1 can be configured for this (not to be confused with an EIS Aux). It can be configured to respond to a ground (Active Low) or voltage (Active High). The voltage can be supplied by the built-in EFIS pull-up. The default thresholds are around 2V low and 5V high but they can be changed. Typically you would configure it as Active Low, turn on the Pull-Up, and connect the analog input to a momentary push button that grounds when pushed.
