Fuel Level Tables
Nick U
Fuel Level Tables
Post by Nick U »
I have dual HX's installed.
They way the HX's are set up is: I have fuel level mapping tables in both EFIS's and the need to add data and ensure both EFIS fuel tables are in sync otherwise my fuel level is not consistent on both EFIS panels.
Is there a way to set up the system such that only one EFIS table is used for fuel level input and tank mapping, and the tank levels are transmitted to the second EFIS?
I would like to set up the system such that I can see the fuel levels on both HX's but only maintain one fuel level mapping table.
Re: Fuel Level Tables
There's currently no way to automatically sync the fuel tables, or transfer only the calibrated fuel level to another display. However, you should only need to set the tables up once.
